how do you cure a stumble off idle, the car run great after the stumble, i know a lean condition causes a stumble. heres what i have ,87 gn i installed a new iac , new tps , new maf , new 340 walboro pump, set fuel pressure 42 lbs, here are my scanmaster readings, o2- 680 af 04 lv8 32 int 128 bl 132 rpm 800 tps 42, iac 17 cc 25 to 255 , motor . te 44 turbo, terry houston down pipe, 50 # inj ericks chip, 206/206 comp cam. stumble causes bad 60 ft ,,,. 2.44, 60 12.24 et 113.88 mph i need help? jedeley
