Stumble
ITSAV6
It's my Granny's car!
Meant to post earlier but had a weird stumble between 1500-2500 and it turned out to be the cam sensor was loose and you could see it moving slightly when idling. Reset it and tightened it good and stumble went away.
Got roller cam due to wiped lobe:banghead: on stock cam after refresh and did a flat tappet 206 but had trash in bearings so rod bearings went to :poop: Knock on wood I built it correctly:)
