http://ihadav8.com/forum/VortexBuicks/basics.htm
Going off of what was said from here under this section:
Fuel Pressure Regulator
The cars originally came with a non adjustable fuel pressure regulator that put out about 40 psi of fuel pressure when the hose was disconnected from the engine. The TTA cars came with another regulator that was also non adjustable, but, it had a bit more pressure when the hose was off and typically showed 42-43 psi when the hose was disconnected.
When the hose is attached as is normally the case, the vacuum created by the engine will pull up on the diaphragm in the engine and the fuel pressure will drop to about 33 or so in the non adjustable factory regulator on the Regals, and, to about 36-37 on the TTA's.
Note that in all cases that I discuss, the engine is running. Also note that the vacuum created by the engine will vary due to engine condition, engine combination, and the load on the engine at the time. My numbers above are in Park, engine idling after being warmed up.
When boost is applied thru the hose to the regulator, then the fuel pressure rises. A properly working regulator with an adequate fuel pump will increase the fuel pressure by one pound for each pound of boost applied to it. That means if the fuel pressure is 43 psi with the hose disconnected, then the fuel pressure should rise to 63 psi if one is running 20 psi of boost at wide open throttle.
Note that chip makers specify a fuel pressure for their chips. A very common number is 43 psi and this number refers to the "hose off" pressure with the engine running.
Be very sure that you reattach the hose before driving the car or very bad things will happen if you bring the boost up.
If your fuel pressure is set too low, the car may run too lean. If it is too high, then the car will run too rich. It is very important that the regulator provide consistent fuel pressure if you expect the car to perform consistently and safely. A properly working regulator and a fuel pump that can meet its demands are one of the basic requirements on a turbo car.
