Stumbly rough idle.
so i finally got my new to me 87 GN on the street. TT chip, egr delete, 60 injectors, exhaust and cold air intake. The scan master shows iac at 02. Is this normal?
No its not. What is your tps #
Sent from my LGMS631 using Tapatalk
Both are going GN to be adjusted at the same time.
You know how to?
With that little bitch right there
Back it out some a few turns
And check the iac number again
Let me know what happens
you adjust your TPS with the two screws on the sensor loosen them up and it will move up and down.
Watch the Scanmaster .
You can have the car on when you’re doing this doesn’t fucking matter
Set the IAC then the tps . Open the throttle blade to lower the IAC number close it to raise them . With the screw that was circled in a pic
Thank u, will do. On a sidenote. Is itjust the nature of these cars to have a harsh vibration and rough feel while idling? My car doesnt seem very smooth.
Nope
When running well and especially in stock form.
They run and drive like a Cadillac
