T
Turboaddict
Guest
the sump filter i got from Performance transmissiions has a slight problem. when i went to push the filter neck up in the bore until it stopped, the tab whole between the tube and valve body bolt hole had and inch of space between them
This is as far as the filter neck will go up. the valve body bolt hole will not touch the tube of the filter. I think the filter neck is a little wide or something. What should I do?
