Super T-76 turbo or T-76 turbo
Hey guys,
I was wondering if any of you are running a Super T-76 turbo or a T-76 turbo?
If you are ,,I was wondering what kind of HP & torque you are putting out?
Also, if you could post you times & MPH in the 1/4 mile I would appreciate it!
Just trying to get an idea on what these turbos can produce.
Last thing, what size turbine housing & turbine wheels are you using?
What psi? also.
Thank you!!
T76 single bb
Q-trim, .96 AR
9.28 @ 147 mph
22 psi boost
Had room to push the boost higher, but didn't get the chance.
Good horsepower gain up to 1050 hp. Becomes inefficient past that. I believe you can sqeeze a little more out of the super. Plus, I believe the super is more surge resistant.
Thanks Donnie for the reply!
I was wondering if you could tell me a little bit about your combo?
Size of engine,
Weight of car, slicks(size), trans used, methanol injection, race gas,converter stall, trans break, etc,,.
I am not trying to copy you, just gathering info on what it takes to go as fast as your time posted.
Thanks Again!
Hank
You probably don't want to copy my combo. Too expensive and troublesome. Plenty of people on this site have done the same with much less. I'll be listing all my specs on the timeslip and combo section. Some of the specs are listed now. I'll be finishing it off over the next week or so. I'm planning on making it very complete for everyone.
