Surge performance chip
Hector Hernandez
Al throttle no bottle :)
I got these when I got my Gn don't know much about the they are one of expensive like to get 100 shipped for both
10% more power and 15% more acceleration. Can't argue with those numbers!
Ill throw it out there. Erics chips (turbotweak) are burned for your individual set up and are very affordable. Id say 90+% of the people on this board use them. Jay Carter also makes chips and are battle proven over many many years. Bob Baily makes chips as well and offer a wide range if tunability. The reason I would suggest these is support. All three are second to none with your Buick in mind.
Sent from my SPH-L720 using Tapatalk 4
useless on a gn .
the GN uses MAF with narrow band O2 correction using BLM to drive the fueling up to a point . in low throttle that point is around 15psi
at 15psi the MAF is maxed at 255g/sec the chip is open loop and doesn't look at the o2
at WOT the chip goes open loop and doesnt look at the O2 so that little gizmo would do absolutely nothing
but it will give a false o2 reading and hamper your decision when trying to tune based on the 02 output
for us the translator uses maf tweaking on our cars to change fueling
btw a google for surgeperformance resulted in a body shaping fitness company ??
and if thats the claim its only way of doing it is by adding more fuel
assuming that you have a low fueling issue with your current chip , if your current fueling was correct adding more fuel wont improve the performance but rather the opposite
I'll paypal you ten bucks if you throw them in the trash.
One stipulation is that you must take a ten pound sledge hammer to them before tossing in trash for proof of improving them beyond their original value.
RZ.
Hector, word of advise, as a noobie you really shouldn't sell anything for a while. No one trusts a seller with only a few posts. Many people have been burned by one post wonders. Secondly you need to do some more research on your GN. In short order you would see that device is not going to work for a Turbo Buick.
hector is ok , hes been registered here since february and even though post count says 0 he has been here religiously and posts (he has 193 posts) but none have been in a forum that earns post count
Hey guys I trough i trow out their just to see if anyone like to buy or is interested in that stuff I don't know much about that crap o and by the way your right Erick turbotweak is one of the best that I got my chip from and another thing I don't criticize no one here or any thing all I do is same thing as you guys buy and sell
No problem Hector. Sometimes we have to steer people from the unknown in order to help make sure there is no unnecessary damage.
pacecarta, the for sale area has had it's share of problems. A low post count is a red flag for many members. It is for me. Hector, you should add a little information to your signature, that way people that don't know you will not suspect you are a troll. Don't be afraid to post up in the regular areas of the board.
