Rogue Leader
Eat my valvestem caps!!!!
- May 25, 2001
so I decided to go nuts on this thing today... got on the phone with Steve (TTA850) and went through stuff diagnosing stuff... I ended up getting a Fuel Pressure Gauge and a set of Noid Lights to do a bit of testing. Plus I crafted a harness to run the injectors manually to test them.
Heres what I found: firstly my fuel pressure is fine, pulled a spark plug, my plugs are fine and firing fine, hooked up the Noid light to an injector, the injector harness IS pulsing! But the car STILL wont turn over.. I have my friend Mike crank the motor and i feel the injectors and they feel like they arent clicking... but I have pulsing at the harness?? I then take my manual injector harness and pop the injectors off the battery... sure enough they click, so the injectors do work, just for some reason the pulsing is not firing them... THEN we check the voltage... I have 11.4 volts at the injector harness... hmm a little low it seems. I have 12 volts at the battery... HMM... THEN Steve suggested I try running a battery charger in Jump mode which will give 13.5 volts. GUESS WHAT it starts fine.!!!!
Turns out now testing the batery when cranking its only putting out 10 volts... It seems the battery is BAD... Hmm thats what I thought in the first place, should have went with my intuition...
Just FYI how much this all cost me (and should have cost had I went with my first suspicion):
VATS Key - $25
ECM - $69
Coilpack & Module - $75
Noid Lights - $29
Fuel Pressure Gauge - $29
Optima Battery - $90
Total - $317
:doh:
Should have been:
VATS Key - $25 (needed it anyway)
Total - $115
Hey at least I have a spare ECM and coilpack now... never know when that stuff can crap out, everyone says its good to keep a spare...
VATS Key - $25
ECM - $69
Noid Lights - $29
Total - $317
:doh:
Should have been:
Total - $115
