Looking to upgrade my shocks on all four corners to first maintain the best traction I can on the street. The car might see the track 3 times a year at the most. Would also like to achieve a better stance with possibly lowering the car sum (maybe 1" or more). The front suspension is stock with bilsteins and the rear has hr parts upper/lower control arms with sway bar and bilsteins. One shop recommended to put coil overs in rear with 2" drop spindles in front. Other said coil overs on all four corners. Also would like to address or not increase bump steer. I do not want to upgrade the front control arms at this tho. What have you guys found to work best?
Sent from my SM-G935V using Tapatalk
