SignUp Now!Rent a plasma cutter and cut a rectangle out of the frame where the rust is. Then cut a new piece of steel(similar size and thickness) weld it in with a stick welder or a mig. Grind the weld so that it is flat and then rebolt or anchor the sway bar link.
Before re-welding the new piece back in, don't forget to tack weld a nut on the back side of it (which will be inside the frame once welded...) so you can screw the bolt in...
Claude
+1
Or get rid of it and buy an HR rear bar.
HR bar or not, you still need to fix the rot before it gets worse.
I definitely am going to be fixing the rust. And of course I care about my car , I've been wanting one of these for as long as I can remember. I haven't had the chance to look over the rest of the frame thoroughly, but from what I can tell thats the only spot. I think I'm going to take what turbomatt said and cut out all the rust, re-weld a piece back in, and then POR-15 the area. I don't want to send this to a shop because I want to do this car MYSELF.
If I re-weld a piece in, will it be strong enough?
thanks for the input guys
-Chad
