Your car handles fairly well but you still have some understeer on the car. Not being a hater here, but there are a few tricks you can use to get rid of it and still keep the ride you like. Shorten the front sway bar links some and you'll get less nose dive effect. The shorter links will make the bar react quicker and help you.
Good eye, it does still understeer at the limit. The understeer it currently has could easily be dialed out with a more aggressive front alignment. I still have it toed in 1/16" to cut down on tire wear.
jlat said:
hello people; Turbo6in Ky. Could you talk more on your set up? It looks dialed in. Is that a compitition with similar cars or do you just run against yourself? Nice run.
thanks
IBBY
It's an SCCA Solo II autocross. Cars are classed according to make/model and modifications. I can't say I win, but I'm never last, which is a big accomplishment considering my GN ends up in SSM with much newer (and lighter) vehicles.
My setup is pretty simple:
Energy Suspension 3.18110 Poly Master Kit
OEM Rubber chassis side rear trailing arm bushings
Moog 5660 Front spring (639 lb/in)
Moog CC651 Rear cargo coils (progressive rate)
Pole Position 9200M adjustable upper A arms
Upper Ball joints from a 1982 Chevy 1/2 ton pickup truck
Bilstein B36-0949 Front shocks
Bilstein B46-0929 Rear shocks
Wilwood 140-2508-B front brake kit
Stock Swaybars
Bridgestone Potenza RE750 245/50R16 tires
Now, the Pole Position arms apparently are not available anymore. No worries. gbodyparts.com's tubular arms and a set of Howe tall ball joints will actually work better. I put my car together before those parts were easily available.
v6underpressure said:
Many out there will tell you the stock bar/bushings are fine and that new ones/poly wont make a difference.
Nobody's saying they won't make a difference. They will. I'm just saying that bars aren't necessary in most instances. The Edelbrock kit, being a one-and-done box of parts comes with bars, springs, and that match. If you go that route, by all means put the whole kit on.
But if you're looking for parts to make your car handle better but aren't interested in dropping $1500 on the kit, replace your springs, shocks, and tires first and see where they get you, THEN start thinking about swaybars. You may end up like me and be perfectly happy with it.
And if you have the money, get a Watts Link. My car is severely hampered by the stock four link at this point. When you get into a slalom, you can feel the rear swaying around and pushing the car places it doesn't need to go. The stock high roll center really makes a mess of things.
