opeltwinturbo
- May 26, 2001
When I switched from a 12V to 16V system the car went dead lean. I was not able to start the car on the old 12V program. I had to fatten the enrichment vs coolant temperature by 12% at 63 degrees just to get it to start when stone cold. Once the car is running, the VE table off the old 12V program seem to maintain a decent idle. Correction is 1-2%. After the car warms up, it doesn't want to start.
Has anyone else switched to 16V and had similar experiences. If so, how much did you have to fatten the program, where did you fatten the program - tables or enrichments?
I can't wait to install the 5 BAR MAP sensor. I understand that tuneup is also lots of fun.
