forcefed3.8's
Buckeye Bullet
 - May 26, 2002
I am getting ready to switch to an AEM 3.5 bar MAP. What wires go where? Just want to make sure I am doing it right.
SignUp Now!This should all be done in the tune you sent me, correct?I'm out of town tuning and going by memory, but I think A is ground, B is 5 volt, and C is signal.
Remember, when you swap it, you will not only have to change the fuel calc to 4 bar and change the MAP sensor calibration, you will also have to rescale the VE, Spark, & Target A/F tables.
Yes. You're all set Rob.
Norbs: This doesn't surprise me at all. Have you tried using their supplied tunes? Or injector offsets? I consider them a guide line to get you close. If Alan thinks the 3.5 bar is off, he ought to try the 5 bar.
Allen is as sharp a dude as they come. His car is insane. He is an engineer and thinks outside the box of the normal train of thought with his FAST equipment. I spent an hour on the phone with him on Wed asking questions about the FAST touch screen dash and EGT module. He uses the dash for logging and info way differently then I have read others using it.
He would have to really get into specifics as this is all very new to me. I'm hoping to get my equipment very soon. I'm going to be with Cal at Norwalk in 2 weeks and very quietly watch over his shoulder to learn as much as I can. I have another year to finish my car, so play time will be on the computer only.
Side question...I run an AEM Wideband O2 right now. Is it good enough to run with the FAST or should I look into a different unit?
