Nov 25, 2003 #1 2 2QWIK4U Member Joined May 27, 2001 Messages 584 Wondering what the symptoms of a bad calpack are.Thanks!
Nov 25, 2003 #2 B bishir Serenity Now Joined Aug 11, 2002 Messages 4,967 When my coilpack went bad the car would pop and miss under heavy boost. Use an ohm meter and you should have between 11-13k ohms on each pack. James
Nov 26, 2003 #3 N NC87GN johnny boost Joined Aug 15, 2001 Messages 496 If you are referring to the calpack inside the ECM I had one that caused trouble. The symptoms were the car would start and then immediately shut off or idle quality would be very bad like someone pulled a spark plug. HTH Mike Banas 87GN
Nov 26, 2003 #4 B bishir Serenity Now Joined Aug 11, 2002 Messages 4,967 Oh, I though he said coilpack
