T&D roller rockers
87-TURBO-T
do these require special hold downs on stock heads or do you use stock hardware? thanks
Mine came with shafts & supports...
Looks good Carl. If you take the rockers off for some reason please measure the spacers for me. I've got some KB's that use springs instead of metal spacers and I'd like to make some spacers for them.
I would be happy to help you, however, I no longer own that car. I had to step up to a faster GN. ;)
In case you didn't know, You will need to machine the rocker pedestals on stock head to accept the T&D rockers.
Dave
With the spacers there are also thin shims on each end & TA sells them in 2 sizes I think when I got mine. I took one down a bit to make everything sit dead centre.
I bet TA would sell the shims & spacers as a kit or if not T&D would.
Dave
I know that Dave. I just havent done it yet.
I'll have to call them and find out I guess. I was hoping to make them myself though. The shims I already have but it's the sleaves that I need. The KB rockers are basically Harland Sharp rockers so I probibly should contact them.
