t link giving crazy info
crazygn
10's here i come
My t link has been hard to get on the past few days , then it gives crazy info . It tells me iam hitting 5psi boost all the time and siome times jumps to 15psi but i dont have the boost sensing hooked up. It reads my o2's at 780 then drops to 100-200's. My batt volts go from 13 to 6 volts. It even said i was doing 151 mph the other day when i made a pass. It seems to jump back and forth good info one sec the next crazy stuff, about every two sec.
what could do this , it also reads 780's on the o2's at 40psi fuel press and 780's on the o2's at 31 psi fuel press with the vac off. I dont get it and cant tune my car like this.
any one no what this is.
help please:(
Sounds like something is loose or you have noise in the ALDL circuit (or the ECM is getting noise).
One thing to check ... is the ALDL mode "on"? You have to look on the dashboard screen (v3.0) or on the numeric screen (V2.13) at the ECM mode.
If ALDL mode is on, the fix is on the TurboLink Support Forum:
http://www.turbo-link.com/discus
Go to Troubleshooting and then "Crazy boost/volt readings" topic. Procedure for disabling ALDL mode is there.
Also, we're always available via email (tlcustomersupport@acceleratetech.com) or the phone (970) 226-3867and we're here to help.
It is, or it isn't in ALDL mode? :confused:
What version of software is it? What version of cable (the new one or the original?)
Regardless, it sounds like something that just started, so it might be as simple as something loose or zapped in the electronics.
Send it to me with return shipping and I'll run it up on the diagnostics bench and fix it for you.
Accelerate Technology, Inc.
3538 JFK Parkway
Suite #3
Fort Collins, CO 80525
Another thing to check ... have you installed any new software or changed anything on the laptop lately? Like fax software? A PDA?
We'll get it figured out ... one final thing, drop us some email at tlcustomersupport@acceleratetech.com if we need to coordinate or to follow up. That way I'll be sure to see it and we'll be able to keep a log in your customer record so multiple people can help.
Thanks!
sorry , its not in aldl its in nomal . As for the software and cable, i dont no any thing about lab tops. The cable is a tan color and is two peices with a plug in the middle, the end is black that plugs in the aldl and the otherside has the spot for the 4 aa batt. The disk is orange and is a v2.13 ms-dos version.
Iam going to check for a lose wireand check the 4 aa batts , if it come down to it what would you need me to send. My dad loaded the disk in the labtop , could i just try to reload it. Or is it probably in the cable.
thanks for all the help.
Really all I need is the cable ... software is probably fine. Make sure to send the whole thing (all parts).
If you use the batteries, you need to zip tie them up so they don't pull on the wires. It's possible it just pulled the red wire loose from the board (which causes erratic power to the circuit, even with no batteries).
Easy fix in that case ... just send in the cable and we'll get it all fixed up! Also, you might want to look into the v3.0 upgrade ... uses a different port and shouldn't require the batteries any more.
tryed new batt, and checked all the wires and the same thing. It was ok tell it hit about 160* and i made a wot pass. Then it started to jump around, the prom id was jumping from 0090 to 0045, the speed want to 26-0- then when i let off for about 6 sec it want back to 99mph and want down from there.
let me know what you want sent, or if i should try to reload it again and i tack care of it.
thanks for the help.:)
