- May 27, 2010
I would recommend the 7211 - 1978-1987 Buick Regal (All models including Turbo Regals) -
T-Tops Reproduction Anti-Rattle Weatherstrip Seals (2)
The original stuff is usually dry rotted in there. I would not recommend putting anything on the outer weatherstripping. It's used a channel for the water to run off and down onto the door windows. Thats why its important to have a good seal on the windows. If you have any kind of gap above the window you can take the door panel off and adjust the bolts to let the window come up a little more tighter or replace the T-top hatch wheather strips.
