T-top twin gauge holder, gauges, ground stretcher, pinion snubber and more
williab9
All parts new. Prices do not include shipping or pay pal insurance (add 2.5%). PM for interest and provide address for shipping estimate.
NEW VDO 80 PSI electrical Oil Pressure 2 1/16” Gauge part number 350 040, Use with VDO Sender $35
NEW VDO Gauge part number 360 005 Sending Unit, Oil Pressure, 0-80 psi $35
NEW VDO 250°F Water Temperature gauge electrical 2 1/16”, (Use with VDO Sender) part number 310 039, $33
NEW VDO Temperature Sending unit 250°F/120°C 3/8-18NPTF, part number 323 421, $15
New blue painted twin gauge holder for T-top cars. T-top Gauge pod replace the short T section by the windshield of your T=top GBody. Fits all GBodys with T-tops and holds 52 MM 2-1/16" gauges. $45
NEW Caspers Electronics 102040 Ground Stretcher Kit. Good grounds are absolutely essential for proper engine sensor operation. The factory located wiring grounds are less than adequate for long term stability. ground stretcher kit addresses the problem by relocating the grounds, extending the wiring, and providing braided ground connections to the engine and firewall. Used on 86-87 turbo cars ONLY. $35
NEW kirban performance 1986-1987 Buick Turbo Regal -CUSTOM-MADE DRIVER’S SIDE POWDER-COATED BLACK RELAY COVER $15
NEW Drive shaft pinion snubber $15
