MNcarbturbo
What's Fuel Injection?
- Mar 9, 2009
Wagon still isn't swapped. Been just driving it as is in between working on my 2+2. It runs so good that it's tough to justify taking apart until it's winter. I have been slowly hoarding parts here and there. Grabbed a 200R4 crossmember and turbo and heat shield.
Also decided to abandon the LC2 dash swap. The guy with a SBC swapped rusty 84 GN in town decided to not part the car out. Good news is I robbed the fiber optic speed sensor and VSS buffer out of my 2+2 (since it's LS and DBW with a t56 it didn't need it anyways). I am pretty sure it will fit in my stock 80 cluster and feed the ECM everything it needs for DCFCO and TC lockup.
I did redo the headliner. My glue was about 6 years old and must have been going bad, it's already sagging in the rearmost piece after the first day in the sun. Not sure if I am going to be able to peel it off again and reglue it or if I will have to buy more fabric and do it again.
Other problems, trying to find my return fuel line situation. Have an earls saginaw line to AN adaptor and tried a AN 90 but it was too wide of a bend. Got a hydro JIC -6 90 but its also too tall. Anybody have a solution to getting a return line on the stock FPR? Hits the coolant crossover about 3/8 too tall. I could resort to having my TIG welder guy cut the hex out of the adapter and butt welding the halves together or just welding a female 90 AN line directly to this adaptor fitting but if something is available off the shelf I'd like to go that direction.
