T108 for bluetops w/alchohol & 93oct
PaulRV6
Does anyone use the T108 for Bluetops with 93 oct fuel and alchy? How will it work?
I was all set to go with the t100 until I realized they do not make one for the 36# injectors.
paul
It will ping like crazy on a stock turbo and stock IC.. neck or not.
But I know, there are those that will say it will work. At worst you lose 25 bucks trying. Unless you run like 19 PSI boost.
My suggestion is the thrasher 93 and up the boost.. works tremendous with alcohol. Want a better chip, contact Eric Marshall, have hime burn you one for your car.
I run a T108 for stockers - be prepared to throw some serious alky @ it. The T92 will be easier to make work - but it doesn't have enough timing for my liking.
Ditto........call "Tweeeeeeeeeak" :)
