TA-49 3000 or 3200?
wheelin
I'm thinking of ugrading my d5 as its stall 2400 is not cutting it. With my new 49(PTE .63 HOUSING) I'm thinking of Pat's 10 inch 3000 stall. What do you guys think?
thx mike
The 10" will flash alot higher than a stocker that stalls to 3000rpm on the brake even if they are both rated at 3000 at zero psi. Which in turn will really enhance the spool rate. I would step up to the .85 ex housing and run the 10".
