I am using a TA-60 turbo with Eric's TurboTweak street chip,. I ran approx 100 octane at 18 lbs. of boost and was getting considerable knowck retard (3-4 degrees). I lowered the boost to 16 lbs. and had very little knock retard, about optimal O2 readings as well.. Is the boost level set when you buy an aftermarket chip and it automatically retards the timing when you go beyond it?.
I am hoping to eventually run this car on up to 25 lbs. of boost. What would be my best option? I was under the impression that I could run at higher boost levels with the aftermarket turbo and chip. but 16 lbs. is all I can muster. Its been disappointing to say the least.
