Copy your Directscan file and change the extension to .txt and add it to your post as an attachment. Looking over your DS file will help rule out some things. Could just be false knock on the shift. If your timing was off across the board, it would not go away as you describe.
Erics newer chips let you change the settings through the gas pedal since some people do not have AC like yourself. It is much better to change the settings through the chip than through adjusting the fuel pressure. Most people adjust the fuel pressure because their chips do not let them adjust the fuel settings and in the past that was the only way to do it.
I'm sure Eric will work with you if you have an older chip that needs AC and your AC doesn't work. In the mean time post your DS file to see if anyone can help.
