TA Billet Cam for sale-needs repair on one lobe
jmendlik
I have a TA Billet Hydraulic Cam grind 224/224. This cam has Odd fire snout w/even fire lobes machined for TA thrust plate. will fit 109/stageI/Stage II blocks
Cam needs to have 1 exhaust lobe (#6) fixed due to faulty lifter that marred up the lobe. I talked to Bullet Cam and they could repair this cam for $200 dollars --they could fix the damaged lobe and keep it at 224/224 or do a total regrind of the cam into anything someone wound need as long as its smaller than 224/224. Billet Cam cores are non exisitant and this would get someone a cam in less than 30 days once its sent in to be repaired. I'm selling the billet cam for $750.00 . If your serious I can send you pics. My price is firm as nobody has cams available --located in IL. JM
Send to Bullet Cams ( Bullet Cams) and pay them to fix the bad lobe or regrind to whatever new specs you want and your up and running with billet roller hydraulic cam.
This Billet Roller cam was in my fresh stage II 276CU Build until a morel lifter link bar button broke causing lobe to be marred. Engine builder said this motor could spin to 6500+ with this roller cam. Build had less than 500 miles on it when this issue occured.
