Ta downpipe PUCK froze up
ShaunDonWe2
Has anybody had any problems with there downpipe puck freezing up? Not even 1000 miles on pipe and its frozen.
Damn, totally un-cool. Any feedback about the problem, cause? Seems like someone would chime in about this. First time I have even heard about anything like this. With any new down pipe.
On my pipe, there wasn't enough in and out play to keep it free moving. I cut mine apart, ran some fine sandpaper over the shaft and tig welded it back together leaving a little more end play. Haven't had a problem since.
Yeah it went all bad for me, everything was new i spent the money on ta pipe and headers and that pipe but its froze
Very ticked off, they told me
Condensation from weather and carbon buildup could cause it to do so, but i aint never had my stock dp puck freeze up so... What does anyone suggest i do about that puck?
Condensation from weather and carbon buildup could cause it to do so, but i aint never had my stock dp puck freeze up so... What does anyone suggest i do about that puck? Cost me block, turbo, and anything that could be damaged.
Cost
Ive been thinking to do this really, street car mainly so would i need it?
for that matter does a street car need a 3.5" downpipe , i have a 3" pipe on my 86
True! I just wanted some of the best on my car that was the only reason but yeah you are right
atr pucks used to stick too
I have one on my T.
When I got the car, I went over it, and found that the gate was frozen shut so tight, I had to grind the arm weld off, drive the shaft out w/ a hammer/punch. So much for the lyin asshole seller, that claimed the boost was "set" for 18#.:finger:
Honed the sleeve, polished the shaft, reassembled.
I noticed that the sleeve had a very small hole in it. Appeared to be a lube port.
BS.. It's a design problem!
....... What does anyone suggest i do about that puck?
Call TA and they should fix that issue.
If you sent me the pipe and cover return shipping, I will replace the puck assembly at no charge.
Thats what ive been told it was a design problem, ive got the rjc puck already also
