ta knock offs
i hear Sam still has some or im sure you can still order some BA performance
Don't bother with them. Get the T/A's. There is alot more to getting the knock offs to work properly than most guys realize. Brian
I have the T/As to BUT he wants to save $$$$.. time isn't worth anything anymore so he should just get the ebay ones and make'm fit :p
these were Sam's. And yes, I got my money back.
I agree just save up your pennies buy the real deal and be done. TA's are beautiful, welds are as nice as my Kooks and they fit like a glove.
If anyone is interested, you can see what is needed to get the Knock offs cleaned up by visiting the "Cottons Performance" board. Go to the 4" down pipe thread in the "shop progress" section. Brian modded my knock offs when my GN was there for the down pipe. They (MAY) bolt to the heads, but the ports are off alignment among many other things. In fairness, I was going to hack off the turbo flange anyhow for a 4bolt, so I bought a set to see what it would really take to get them right. I'm anal about my stuff, so everything was massaged and modded. The crap v-band flanges and clamps were replaced with real stuff, tubes were cut open to clean up the welds/holes, head flanges were welded up and ported for perfect port alignment [outer ports were 1/4" off], and a 4 bolt turbo flange was installed. I have into these, what T/A's would have cost me, but the T/A's need some clean up also, and I would still have had to install the turbo flange. What I ended up with was a real nice set of port matched, custom headers for $1000. Also take a look at the beautiful Job Brian/Jack did on the 4"DP and external gate, while still retaining my heat/AC.
