got this car a couple month ago, and decided im going to do twins, so this stuff needs to go.
this is what everything looked like in the car
TA Stainless coated headers. comes with ARP bolts. comes with all hardware. coating has seen better day, is starting to flake off a little (look at pictures). is for 3 bolt turbos- SOLD
Turbonetics t series 65/66 ball bearing turbo. exhaust housing has been coated and is .63 3 bolt housing. no shaft play. comes with coated intake and filter. also comes with oil drain back to block, 4an feed fitting, 4an feed and return fittings for coolant- SOLD
coated steel 3" Downpipe does NOT come with wastegate, but flanges are for turbonetics rg-45 wastegate and similair. has O2 bung welded in. has a couple of dings in it to clear the TRZ control arms - SOLD
Precision 1000hp Intercooler with all coated charge pipes. does NOT come with blow off valve. bov flange is for Turbonetics godzilla blow off valve. comes with couplers and t bolts and mounting hardware. couple scratches on the coating, but you cannot see them when installed. precision no longer makes this one, so get it while you can. 600 obo shipped - sale pending
