SignUp Now!.........I'm currently running 20lbs of boost with the Alky knob at just a tad over 6. This past weekend I took the car to a 1/8th mile dragstrip and ran a best of 8.9 seconds at 73 mph. ..........
Probably running too rich.
Here's basically what happend.
First Pass: 20lbs of boost, alky set knob at 6 no added timing (TT Street chip). 8.9 sec at 73 MPH. O2s at 792 and knock at 1.4
Second pass: Brought the boost up to 21lbs and tweeked the alky knob to a 6 1/4, no added timing. 9.2 at 75 mph. Don't remember the O2s, but no knock.
Third pass (Car goes sideways pass): Turned boost to 20 lbs left the alky alone and added 2 degrees of timing, 10.4 at 73 mph. O2s at 820 and no knock.
I think I'm going to start writing down all the settings and readings on the back of the time slips from now on. Also thinking about tuning with no boost build at the line. I'm not experienced enough to build a consistant amount of boost every single time, plus need to work on traction issues.
Hey Eric.
Without any attempt to insult your intelligence, I would say 23-25 “Theoretical”.
As you know, each car is different, but the HP benefit of the 49 will show in the 23 PSI + area. If you were testing at the track, and the car did not pick up any MPH after 21 PSI (For example), than you know you reached "the point of diminishing returns for your combo".
Thanks for the reply Jerryl, my "intelligence" is always questionable :redface:
I'm currently running 20lbs of boost with the Alky knob at just a tad over 6. This past weekend I took the car to a 1/8th mile dragstrip and ran a best of 8.9 seconds at 73 mph. I feel my combo has more to give me with the alky and 93 pump gas.
Eric,
Was this run at 20PSI and Alky?
The 73 MPH seems low.
I'm running a Pat's Performance Converter 1003XHD 10” 2004R W/Anti-balloon Plates. I really don't know what the % slip is for that converter, but if it's important information I can email them. Next time I'm in the car I'll note the tranny shift points.
I'll been thinking about buying one of those Powerloggers from Full Throttle, but have to save up some $$$ to get one.
Anything over 24 PSI up to 28psi and the Ta49 will pull hard.
73 MPH is low, about 6-10 MPH low. @ 73 MPH in the 1/8 that equates to 93-95 MPH in the 1/4 which puts you around 14.0-14.5 depending on traction. Not bad but @ 20psi with your mods your tune is wayyyy off. Try this; turn off the alky, start boost @ 15PSI (or as much as you can run on pump without KR) & 43PSI fuel pressure make a pass. Don't worry about traction for a while. See what MPH you trap at. No kr turn FP down 2 #'s make another pass, trap speed increases no kr decrease fp 2 more #'s. Find your target A/f ratio then start adding alky, boost and FP.
You should easily be able to run 8.0's - 8.5's @ 20+ PSI.
Still trying to learn and sorry for the hijack.
Correct me if I am wrong please.
So by finding you target a/f ratio and keeping it as high(lean) as possible without kr you find where your car likes to be and make the most hp. So then would be best to start off at stock boost level and adj fp as above for best mph and no knock. Then add boost and fp to maintain a/f ratio until kr appears. Then when kr starts stop adding fp and start adding alky until kr stops and a/f comes back down to target level. Then as you continue to add boost should you add alky or add fuel through the chip or both ? Or is that part of tuning that we all have to figure out through trial and head gaskets ? I do realize that weather conditions can effect your tuning which I am not going to obsess over. As long as it runs good with no knock I will be :biggrin:
Trap speed, is that your mph at the end of your measured run ?
What ballpark range should the a/f be at wot?
After you get your a/f correct at your target boost level then would it be time to increase your timing ?
ok so im still learning all this as well. say im running 11.4 on my WB and im at 16 psi (no alky). i turn the on alky and turn the boost to up to 25 psi.Since im adding alky its droping my air/fuel even richer to 10.1 on the wb @25psi of boost. so now i back my alky off alittle to right till i see some knock then i add just a tad more alky so there is no knock. now say my a/f is 10.6 on the WB would i pull fuel now from the chip to get back to the target a/f of 11.4? then lets say i start seeing knock when im pulling fuel out i guess i would need to add more alky to supress knock while still pulling fuel? then lets say i want to run more alky due to the decrease in intake temps so i would add more alky to cool more and then pull even more full out of the chip to keep my a/f at 11.4 correct? i think this is what i need to do i just never really put it down on paper. if someone can answer this thank you.
