TB to turbo gasket
Martin U
Any one know where to get on of these? I'm hoping this will lower my BLM's I'v been chasing.
mart
Try this
A thin coat of Loctite 518 will work just fine as this joint is under vacuum on a stock setup.
I found a felpro turbo mounting set stashed on a shelf. It had the gasket plus various o-rings in it ,I think I picked it up for the turbo adapter o-rings.
This was after I went to pepboys looking for the permatex you recomended,which they did not have anyway. I have never tried that stuff,I do like the "RIGHT STUFF" alot!! That was my 2nd choice.
Thank you Lee for taking the time to help me out. I sure am getting a long awaited education on these engines. This being a last ditch effort to get my BLM's into range
Mart Urbanski
Cut and pasted from one of my earlier posts, in case someone needs the number, or searches. ;)
HOT AIR turbo mounting gasket set Felpro ES 72660 (includes 1 60656 TB gasket, 4 90457 Fuel feed seal, 4 90467 fuel return seal, 1 90497 adapter to intake man O ring, 1 90527 seal adapter to turbo, 7 92588 fuel injector Oring)
I picked this up at Oreillys autoparts locally.
PS: engine looks bad ass!!
