Jeez Fred......
I wish I knew the terminology. What does 'pull' mean. Although I've read about this many times before. I don't have a clue as to what it means. You think you can school me?
What's up Rich,
Yep I did check that out, (
www.montecarloss.com), but most of it pertains to that other transmission, (you know which one). The brake toggle switch will remain.
It's article goes into detail on the later 12 pin ECM/ALDL and how to bypass and modify the TCC system. This leaves me at a loss since there is no info on the earlier 6 pin ALDL.
Anyway, my goal is to remove ECM control and have it lock up according to the manuel. It locks up at 25 MPH, unlocks at about 30-35, then locks up again at 45, to unlock again at 50-55 MPH.
This seems O.K. to me and this is the way my car runs currently. But I am working on an experiment to retro the car. I'm almost finished with the Non-CCC Q-jet. And Bruce out in the transmission forum was kind enough to send me a schematic on wiring the THM-350C up.
http://members.telocity.com/~familiadiaz/Bruce.jpg
I really don't know what I am going to achieve with this schematic. He has'nt gotten around to answering that question. I do know that I don't want to be constantly flipping a switch all the time and especially not while I am driving long distance. (I don't mind an occasional switch).
The schematic is quite simple and easy to execute. It's the end result I'm worried about. The ECM system will be 'unplugged'. I'll just pull out the ECM fuse. The sensors will remain intact. The distributor, carburetor, ISC will be removed. What do you guys think of this idea?
