WarWagon
Caustic Cacophony
 - Mar 10, 2007
I put this project on hold while other life events are taking priority. I do intend to finish and having this running again this year but no rush at this time.
SignUp Now!Comp 206 roller, it's been in 5 different blocks now.What cam.are you running ?
For sure. More odd things: there's a tapped plugged hole in the rear valley bulkhead, the cam button had a dab of silicone on it and seized to the front cover so the cam was spinning on the spring. Not one single broken bolt anywhere.That prep work is always a thankless job. Sure seems to be a previous GM rebuild. Odd that the engine was assembled with the rods reversed. Mr. Goodwrench must have been having a bad day.
