Blowthrough build repeat.
I put this project on hold while other life events are taking priority. I do intend to finish and having this running again this year but no rush at this time.
Dangit! Soo much getting in the way of getting the car back out. This is the longest it has been off the road. I have been able to drive the 3.8 swapped Impulse to get the Buick 6 noise and feel fix, but it's all motor. One of my newer daily drivers ('11 BMW X5 35D) helps get the boost fix and is nearly the same for the delivery of power like the Buick. When I get focused, I'll put together a stock bottom end 140 casting hot air block. It will have steel piston rings this time and the rest of goodies and heads from the last 109 that popped. I also have some of the last off the shelf ring sets for the 4.1L, I can get that up as a spare short block with stock pistons as well as my old '79 3.8 block that needs cam bearings. The 109's and the 10:1 comp 4.1L builds are on indefinite hold for now.
Updating the interior of my V8Corvair has taken an unexpected priority this year.
Picked up another complete engine to help get the Regal back up.
An '83 turbo 3.8, I'll strip it down and make it the new blowthru testing mule.
Need to check the bottom end but I have two sets of Speedpro steel piston rings to use this time, it will get the 206 roller cam setup and topend from the hurt 109.
This will be better than the current mishmash of parts I was putting together in a 140 block but I'll still build that too as spare engine.
While it's in good shape the new to me engine has bores enlarged more than I prefer.
It's .040 over, so I will to use it as is. It had GM shim steel head gaskets on it and cylinder 5 was leaking some water into the bore.
Actually my mistake cylinder 6 was leaking coolant and the turbo was bad.
The bores are really nice at this size, looking in the bottom end next.
I wonder if this is a GM rebuilt engine, it has .040 over turbo pistons with the steel inserts, I believe the bearings are gm and standard. The rods appear to be installed backwards but it has been running this way, standard turbo crankshaft.
Ooo it almost got me, I thought the 1st cam bearing was installed wrong and almost pressed it out as the oil hole is random. I then looked at it from block side where brass oil T goes. It's grooved! press on with assembly 😄
