TCC solenoid Qs
DorianL
Will applying 12v to the TCC solenoid actuate it? Will reversing polarity blow it?
How is that for two very straightforward questions?
D.
Will reversing polarity blow it? =
D.
#1 = Yes
#2 = Yes, depends on how long it's reversed before Coil is burned.
Oops - I heard a small tick sound when I reversed the polarity (not for long tho')
On other hand nothing happened when I applied 12v. Didn't I read somewhere you needed to apply copmpressed air and 12v?
D.
When applying 12v to the solenoid you should hear a click.
compressed air? Where would one apply it?
Are you trying to trouble shoot a no lock up situation? Look at the fuse on the block, top right hand corner. It says "ecm/sol". If that's not it, then start tracing wires, testing the brake switch, etc.
