Most of the online calculators that I've looked at estimate wheel hp applied to the track, although almost none of them say one way or the other and most people have no idea, and many will argue that it must be flywheel. All of that is why I derived them myself a long time ago. You have to make some kind of assumption about the variation in hp to get an answer from physics, and the simplest one to make is to assume that hp is constant for the entire pass. This gives a minimum average hp estimate, which to me is a good thing - you might make more hp some of the time but if so, you must be making less hp some of the rest of the time
. ET's are hard to reproduce but ignoring that you can derive (I posted this 6-8 years ago if you want to see all the equations) that the average whp = 197 * weight in pounds going down the track / (et * et * et). This equation is exact and includes no fudge factors of any kind, just unit conversions. So if your car weighs 3600 and you weigh 150 lbs so the total is 3750 lbs and you ran a 12.0 you averaged 427.5 whp applied to the track. Relating et and mph with any accuracy at all requires a fudge factor to account for aerodynamics, and here you will get different numbers from different online calculators. The formula is et = constant / mph, and if you ignore aerodynamics then physics says the constant is something like 1450 (that's a real fuzzy memory and a number NOONE uses
). For G bodies I fit the 180 reader's rides times at gnttype.org and got 1356, so I use et = 1356 / mph, so a 12.0 would be at 113.0 mph. F bodies usually mph 2-3 higher for the same et so that number should be changed for them, etc. The mph is much more reproducible at the track than the et, so what I like to do is use the mph to calculate the et then use that in the hp formula. That's what the online calculators do that start with mph, they just don't show the equations and don't tell you what they are using for the fudge factor (I've seen anywhere from 1340 to 1370
). Do the math yourself, and even if the number is a little wrong it will be consistent so you can evaluate changes. For example, if you ran that 12.0 at 3750 lbs and want to know how much taking 100 lbs off the car would help, calculate hp at full weight to get 427.5 hp, and then use that and the lighter weight to calcuate the new et, 11.89. [Hmm, maybe there is something to this cleaning out the trunk business
