SignUp Now!Does anyone know where I can find the compressor map for a TE44? Looking to find it's most efficient operating range. I tried doing a search, no luck. Thanks![]()
The 15 to 25psi range looks REAL good on that. Nice and wide. Surge line nice and out of the way of a usual operating range on these engines. I knew I liked my 44 for some reason.
Assuming your intake filter system isn't unusually restrictive the inlet pressure will be only slightly below atmospheric so assuming 1 bar is a good aproximation for P1. That makes a pressure ratio of 1 roughly equal to 0 psi gauge boost, 2 equals 15 psi boost, and 3 equals 30 psi (and 25 psi = 2.7; boost = P2/P2*15-15). On the horizontal scale assuming a typical bsfc and afr makes hp roughly 10 times the normalized airflow. Looking at the TO4E 60 trim map, the upper tip of the innermost, most efficient island (which isn't labeled but the next one down is 78% so this must be 79 or 80%) is at P2/P1=2.5 and airflow=35 lb/min, which is roughly equal to 22.5 psi boost and 350 hp. Taking into account the exact inlet pressure and ambient temperatures will make a small difference so for best accuracy all the math should be done, but for eyeballing compressor maps this works well.
Yeah. You're basically off the map. I dont know if you're just being a wiseguy or if you really are trying to find something, but with an engine that truly is stock...like no work whatsoever on the intake, the heads, no aftermarket intake tube, stock exhaust, etc, gets you at about 3.2. But something tells me you have some work done to improve breathing somewhere. 450 with a TRULY bone stock engine would require a pressure ratio of about 3.2, which is WAY up there and far from likely. Weather conditions are worth alot of power so who knows.![]()
I estimated my HP, based on terminal speed in the 1/4 (117.5) with 3850# of car weight at something around 450+ HP.
PTE44 (.85 housing), and MSD 50's, front mount. Rest of engine bone stock.
Was I running the turbo dangerously close to overspeeding?
27# of boost btw.
200-450hp is possible with that turbo, and it can be in the efficiency range too. But only if you bring the pressure ratio down to around 2, which is 15psi. To make 450 with 15psi would require big flowing heads, intake, cam, and allt he other crap to go with it. You can make alot of power at 27psi, or at 15psi...the same power. Thats what the map is telling you. You need to increase the breathing capacity of the engine, post turbo, in order to get there.
Cool.Not trying to be a wise guy at all.
This is some good information....isn't the 44 rated at 580hp at the flywheel? i a running 23 psi and trapping close to 123mph with an unlocked torque converter..i punched in the weight of my car , mph, and the hp calculator said i had 520hp at the wheelsSeems a little high but i don't know. i am hopefully going to the track Saturday night to see if i can up the mph some more and get the 60's down. Bob
Sorry Dave, I just realized I forgot to put up a smiley face with the wiseguy remark. Thats what was intended. No intent of being a jerk...Not trying to be a wise guy at all.
117.5 mph on average is an 11.54, and that at 3850 lbs is 493 average rwhp which is about 580 average fwhpWhen I was racing out in San Diego, the car turned 11.60's, and consistent 117.5mph runs. Car with me weighs 3850# according to an official NHRA scale.
