SignUp Now!im running a 2800-3000 10.5 protorque that stalls as it should 2750 zero boost with a te44 .82 exh.. last time to track on 27" mt radials was a 1.57 7.2 at 95 and 11.31 119.96 , spoolup is instant
i built up a freinds car and he went with a 9.5" 32-3400 protorque and with a ta49 with a .82 exh (same wheels as the te 44 but rated less cfm due to compressor cover diferences ) he stals 3150 zeropsi ...and you can argue all you want about how its no good or a poor choice or that it will hurt performance ....full weight GN ttop on 28" mT radials 1.52 , 6.96 at 98mph , and 10.98 at 121
oh and with the pats... id drive it before i comment anything on the stall rating
had one pats 10" that was supposed to be 2800 with a ta49 and never really had a great 60'
he went with a 66bb on the new build so sent it in for a restall to loosen it up to 3200-3400 , according to powerlogger its stalling at 2190 (zero psi) , and he needs 9.4 psi to hit the rated stall of 3200 talk about turbo lag ZZZZ.....
scojack_2001 said:Damn Doc, I just read your sig. Looks like Ive got some catching up to do!! :biggrin:
dont go playing the catchup game with me , your head gaskets wont change themselves
and as far as catching up... you still beat my tired 132k stock heap on a stock turbo even if it was only .004 faster on a downhill track with 30mph wind at your back ,
after the last round on the te44 with no cage the stock turbo is going back in....
 Taking a bit of a break.
  Taking a bit of a break. After reading this thread I went out to check my car (TE-60) and I can barely get to zero boost, I have to really put some force on the brake pedal.
2000 RPM @ 0 Boost fighting the brakes
Do you have a stock size converter was it ever rebuilt(painted).. You want a 10 or 9.5 inch converter about 3000-3200 stall with that turbo ..Night and day difference
