Te-60 turbine housing measurements
49-blues
I have a Garrett exhaust housing that I wish to machine for a te-60 turbo-anyone know the inlet /outlet measurements of the te-60 turine housing so I can have a machine shop make the proper cuts for it.? I think the inlet size of the housing is 2.950" but I don't know what the outlet size is on the exhaust housing.
You need a machined product as an example. Its not a simple throw it in the lathe and cut procedure. It takes someone competent with a CNC some time to duplicate the radius in the housing correctly and there is not room to correct any error. Just send the housing to Limit Engineering and have them cut it for you. Faster and cheaper int he long run and you wont have to worry about an overcut.
+1
A.j.
I didn't know the radius had tone cut as well-I guess I ll send it to limited or precision.
