TE-60 what can I expect from it??
RUQWKNF27
Got a stretched IC, 60 pounders, 3200 9/11, an all the stuff that goes with all this... have any of you got experience with this turbo.. I can get it for a real good price... What will it do 1/4 mile wise??? THANKS
i got a ta60 with a 2800 coverter and i love it. wish i had a little more converter sometimes though. with the 3200 converter i think you will be happy. the ta pulls very hard . the te should be the same and a bit more.:D
sorry . no track times cause i got a broken tranny. you can go low 11s with that though.
yes
ported stock with larger valves also port matched to intake.. Thinking of trying to go 25 pounds with alky seems some are getting away with this without knock. Although I see most running 21-23 lbs which is good also , saves on race gas but i will try to push the envelope!!!!!!!!!!!
Great turbo - I run 26 lbs boost with alcohol. (similar setup to yours minust the ported heads).
With a NO boost launch (off idle) on drag radials I have run
2.0 60 ft (terrible)
8.0 in the 1/8th @ 98 mph with out even trying hard. With a good boost launch car should be very very low 7s.
First time I tried a boost launch (last track trip of the season), I snapped the axles... this year we'll see what she can do.
