TurboWh1
- Aug 12, 2002
When utilizing the stock exhaust housing on a TE60 is the stock turbine used as well? I've pulled apart several stock turbos and the turbine on my 60 is larger in comparison to stock. I thought only the compressor wheel / housing and backing plate were swapped and the rest remained stock?? It appears someone modified the exhaust housing to fit the larger turbine also.
