Whats the difference between the P trim and the Q trim??????
Which would best suit my car...heres my mods....
Balanced and Blueprinted 3.8 Liter V-6
TTA Crank
.020 Bored Block
JE Forged Pistons
Comp 206/206 Billet Roller Cam
Champion Heads 1.17 Intake 1.55 Exhaust - Stainless Manley Valves
Champion - Lower Intake (port matched)
Upper Intake - Stock
55lb Siemans Injectors - Modified ECM
Mark Jackson 17-Row Stretch Intercooler
PTE-53 Turbocharger
Terry Houston 3" Down Pipe with cutout (ceramic coated)
Hooker 2 1/2" cat-back exhaust (ceramic coated)
ATR Blow Off Valve
8.5mm Kenney Bell Plug Wires
Kenney Bell Ram Air (no canister) with a 9" K&N
Volt Booster
Adjustable Fuel Pressure Regulator
9X11 3200 Stall - PTS Converter
Stock Transmission (removed checkball in transmission for quick lockup)
Fan, Fuel, and Converter Lockup Switchs
26x10X15 ET Drags mounted on 15X8 Pro Star Wheels
Scanmaster II, Direct Scan
Fuel Pressure, Boost, EGT, Air/Fuel Mixture, and Oil Pressure Gauges
Dual Air Bags in rear springs
Competition Engineering 3-Way adjustable shocks 60/40 rear 80/20 front
Poly Urethane Bushings in suspension
Mobile 1 Synthetic 15W50 since day 1
Thanks Alot!!!!!
TTA Crank
.020 Bored Block
JE Forged Pistons
PTE-53 Turbocharger
ATR Blow Off Valve
Volt Booster
Thanks Alot!!!!!
