TE60 Questions
bison/ruqknuf thanks for input i willkeep on eye on this thread as i dont want to high jack it from the original poster:biggrin:
Patrick, could you get into more detail what the difference is between the S cover, and S cover with ported shroud??? Is the ported shroud available on the 6265??? And what sort of benefits could one expect?
S cover has a standard straight 4" inlet that tapers smoothly to the inducer of the compressor wheel.
S cover.
The S ported shroud cover has an anti surge ring or ports machined into the inlet. These ports or slotted rings help to eliminate surge under part or half throttle conditions.
S ported shroud cover with bullet hole ports.
S ported shroud with slotted rings. AKA milled style
Yes the ported shroud S cover is available on the 6265 turbo. Benefits are dramatically reduced surge under partial or half throttle conditions. Increased longevity of the turbocharger.
Hope this helps.
Patrick
Not to worry, as your question was a question I had also. :biggrin:
Turned out to a great informative thread, thanks to all.
