Tell me what you think??? MODS ADDED
superballs5337
i just got one of the Walbro GSS340M RX-G77-FPA , from racetronix, i orderd adjustable fuel pressure reg from kirbans, orderd 160 degree thermostat, 93 oct ultra chip, 42 1/2 lb injecters from postons.
update we switched the hoses on my turbo cause they were on backwards and now im getting 16lbs of boost. man am i happy. but i still ahve the hesitation and we think its teh stock fuel pump, so im going all out with fuel. i have the 9in k&n cone cold air intake set up. (homemade set up).
what do you think, how should i be running with all that stuff?? thanks
Don't forget to replace the fuel filter on the DS frame rail in front of the rear tire.
It will have about a cup of fuel in it so get something to catch it.
fuel filter is new on the car. fuel filter is a fuel filter right they dont make peformance ones or something?
ill have to get the scanmaster tool later, im out of money all that stuff cost me around 700 dollars give or take.
also, a pre-turbo exhaust/header leak can make it hess,.
You need a way to check O2s, to see if the Sensor is active at idle.
