Mar 29, 2008 #1 X XSboost New Member Joined Jul 14, 2004 Messages 100 car does not over heat or run hot just one day the temp light came and never goes out. car drives fine start right up any idea??? I might just pull the bulb, I would rather not.
Mar 29, 2008 #2 J jarheadcmchnj New Member Joined Feb 5, 2007 Messages 24 temp light on Did you check the coolant temp sensor ? Check the one with the single wire on the front of the intake. The one by the fuel pressure regulator turns the fan on. Hope this helps ,Dan
Mar 30, 2008 #3 X XSboost New Member Joined Jul 14, 2004 Messages 100 I have a gauge in that location can it be something in the wireing?
Mar 30, 2008 #4 A aminga Chicks Dig the powerbulge Joined Dec 15, 2003 Messages 5,578 If the wire is grounding out on something yes.
Mar 30, 2008 #5 B Blown&Injected Active Member Joined May 31, 2001 Messages 3,721 Does that one turn on the fan? What does the other one do, the one facing forward on the right side?
Mar 31, 2008 #6 A aminga Chicks Dig the powerbulge Joined Dec 15, 2003 Messages 5,578 The one on the passenger side is the Idiot light.
Apr 1, 2008 #7 G gossamer Member Joined Nov 28, 2007 Messages 424 If the wire to the sensor is grounded somewhere, it will keep the light on. It happened to me a while back. :wink:
Apr 1, 2008 #8 X XSboost New Member Joined Jul 14, 2004 Messages 100 yes, i just found it stuck behind the altanator thanks guys
