Temp Sensor -38 on scanmaster correct on PL
czimpel
Boost...gotta get some!
I have an issue where my temp sensor is reading -38 on my scanmaster, but reads correctly on the PowerLogger. Car starts hard when cold, so assuming this is causing the issue. Is this just a bad TS or do I have a wiring issue. Just reinstalled the motor, so wires were being moved around.
Thanks, Cory
Cory you need to move. It probably-38 still outside there.
On a side note I believe -38 is default if it has no reading.
Check your coolant sensor. Drivers side intake manifold. 2 wire. Unplugged or borked.
Thanks Ronnie, I'll try start there. Where does the powerlogger pull its temp data from?
That was it Ronnie, plug was laying in the socket, but never got plugged in all the way. I thought there were only the 2 temp sensors. Learning everyday!
