May 22, 2013 #1 B bad2bone badtobonebuick.com Joined Aug 24, 2008 Messages 109 Suggestions for getting hot running temp under 210+
May 22, 2013 #2 TType85 Well-Known Member TurboBuick.Com Supporter! Joined May 25, 2001 Messages 1,655 Need more info. Are you running a front mount? Are the fans coming on like they should?
May 22, 2013 #4 B bad2bone badtobonebuick.com Joined Aug 24, 2008 Messages 109 bad2bone said: Front mount / Click to expand... Two fans operating properly
May 22, 2013 #5 K kidglok Balls Deep Joined Oct 10, 2010 Messages 2,278 i run an fbody radiator with dual valeo fans, water + RMI 25, 160* thermostat, and it doesnt go over 180 in a north east summer.
May 23, 2013 #6 Buick Mark Active Member Joined Sep 12, 2001 Messages 794 Is 210 the HOTTEST it gets? If so, I wouldnt worry about it, especially since your running a front mount. What temp. thermostat you have?
