speedosack
- May 4, 2008
OK how do you test the functionality of a non-adjustable fuel pressure regulator when it's off the vehicle. I am trying to test a Bosch 237 regulator.
I tried:
1)80 psi pressurized air in the threaded fuel inlet, there was no flow to the fuel outlet
2)80 psi pressurized air in the fuel outlet, it pressurizes and I hear a pop sound from the diaphragm, still no air flow to the threaded fuel inlet
3)drew a vacuum on the vacuum port, regulator held a vacuum, no flow from fuel inlet to fuel outlet
4)30 psi pressurized air in the vacuum port, no flow from the fuel inlet to fuel outlet
5)drew a vacuum on the threaded fuel inlet, no flow through the fuel outlet
6)drew a vacuum on the fuel outlet, no flow through the threaded fuel inlet
does the metal fuel line that threads into the regulator fuel inlet somehow depress a check valve allowing operation? help please.
I tried:
