TFT car left over parts
Bweavy
Car Hoarder
Ok I'm selling these to raise some extra cash for the Toys for Tot car give away. Reasonable offer is all I ask. Remember All proceeds are going directly for toys for Tots.
Ok here is what we have replaced & what we have.
Stock Throttle body
Stock upper plenum
stock clean Vacuum block.
Stock Thermostat housing.
Set of Stock heads
Set of stock headers. I will have to re check the condition of the headers.
Knock gauge
Used visor swivels & visors non illuminated will need re wrapping.
Used door handles & locks. Locks will need to be re-keyed.
Upper A pillars Blue.
blue split bench seat no tracks great shape.
8.5 stock rear end cover.
Stock Inter cooler
Stock IC shroud
Stock IC brackets now powder coated to look new.
Stock air cleaner assemblly also powder coated to like new.
stock upper front control arms
Stock front upper & lower control arms
bad stock turbo.
Cam sensor parts
2 used air dams
6 stock injectors
Front sway bar
rear sway bar
145MPH speedo over lay new from Custom TR parts.
I'm sure there are a few things I'm missing & will update other parts & what is sold.
Brian,
Great idea. I would be happy to donate to TFT for a matched set of locks
woth keys (dors,glove box, trunk). if you have a set.
David
Brian,
David
David the car came with matching door keys.
the trunk key was different.
the column was different
I installed new lock keys on the column & the doors & trunk.
Bump for a good cause.
