On the TH200-4R, the accumulators are on top of each other separated by a plate. Which one is the 1-2 and which one is the 3-4?
Reason I ask:
I've been troubleshooting an intermittent second gear start. I did two things so far since they were easy to get to without pulling the valve body:
1. Replaced the TV sleeve and plunger and made sure the TV valve was set right for each position. I have the Bowler TruShift system which corrects the geometry when using a carb and the TV travel checks out fine. The most common cause of second gear starts is too much TV pressure (over 90 or so). I'm good there. I'm at 75 at idle TV. My pressure gauge and shift patterns confirm my TV is set right. Shifts are firm, no flares, no early or late shifts. Shifts into all gears, downshifts are clean and at appropriate times and I can do all of these shifts without issue: 1-2, 2-3, 3-4, 4-3, 4-2, 3-2 and 3-1, BUT, I can't always get 2-1 when I come to a stop. It usually does go to 1, but sometimes it doesn't, especially after warm-up. Bottom line, the Sonnax TV sleeve and plunge did not fix the issue and everything remained as it was with the old sleeve and plunger.
2. Next, I cleaned the Governor and pressure tested to be sure it wasn't leaking governor pressure to other circuits at the wrong time. No leaks. Didn't expect that to fix it and was right. Did not fix the issue.
I have read that after making sure the TV system is not the cause of a second gear start, the next test is to put the selector in Neutral and back to overdrive and also try 1st and back to overdrive.
Based on the above, IF the 1-2 accumulator is the one I can get to without pulling the valve body, I will get the pin and reamer kit and a new piston seal and try that next.
I may just hold off because I plan to send the tranny to Dave Husek for a full rebuild this winter. Although it's working good, I am getting thrust washer material in the filter at every change and it is increasing so its on its way to trouble, but I still have a little time to drive it yet and wanted to see if I could fix the 1-2 for now.
Thoughts on my plan...right/wrong?
Reason I ask:
- If putting it in neutral and back to OD resolves the second gear start it is likely to be a stuck 1-2 shift valve, or too much governor pressure on circuit.
- If putting it in neutral does not fix it, the try putting it in 1st gear and back to OD. If that fixes it is is likely to be an accumulator cross leak.
