Hi folks, been advised to come here from the corvette forum to see if you can hel me
After having a trans cooler hose blow off on my BTOVERDRIVES LEVEL 3 th200r4 on a parade lap of the track back in sept last year. I repaired the hose, and topped up the fluid. I noticed it was not changing from first to second until above 4,500rpm and only if i back off the throttle! 2nd to 3rd and 3rd to 4th changes are fine under light or hard throttle!
It does drop into 1st when it shouldn't at about 35mph but will not go up to 2nd until I back off the throttle.
The atsg manual points me in the direction of the valve body gaskets either side of the spacer plate? I've checked the Tv cable and pressures and governor all seem to be working fine with an idle pressure of 80-85psi and a full throttle of 240psi when the tv cable is pulled right out
Any input will be greatly appreciated.
Cheers
Peter
Was going to post a link to the thread there but apparently I cant
Cheers
Cheers
Peter
Cheers
