kinrob@xtra.co.
- Aug 21, 2007
Hi All, running a TCI superstreetfighter TH400 behind 454BBC TT in road race application. 2-3 shift gets long-ish towards the end of a race once trans fluid temp gets up. At last tear down the direct frictions were looking a bit sad so I tried inverting the 2-3 accumulator piston to quicken the engagement and reduce slippage (it was already installed without the accum spring) - this involved grinding the castles off the piston top and installing it upside down in the VB. It worked - the 2-3 shift was considerably crisper, but seemingly the reduced accum piston height allowed the 2-3 servo piston to fall far enough down its bore for the servo seal to be damaged and I lost manual second engine braking completely. Questions are 1) does the inverted 2-3 accum piston mod have any undesirable side effects (high wear or failure of thrust washers/bearings etc)? and 2) if it is a valid mod how best to remove the delay of the accumulator circuit while still keeping the 2-3 servo piston properly located in it's bore?
Thanks, Andrew Robertson, New Zealand
